Mensaje
por NACHO_SUAREZ » 16/May/2009, 12:28
Buscando ... buscando... pues he encontrado algunos datos.
El CJ3b y CJ3A, montan :
EJE DELANTERI: DANA 44
EJE TRASERO: DANA 44
TRANFER: DANA T-18
GRUPOS: 5.51
Esto incluye logicamente a todos los Jeep CJ montados con licencia Jeep en cualquier parte del mundo. Incluido mi mahindra .... jajaja.... quien me lo diria unos D44 ...ufff
Datos de los ejes, su caracteristicas:
FRONT AXLES
D27 Front Axle:
Full Floating
Vehicles: '66-'71 CJ-5 and CJ-6; '63-'70 Wagoneer; '67-'71 C-101 Jeepster
Ring Gear: 7.2"
Stock Gearing:
Axleshaft Spline: 10
Axleshaft Diameter: 1.13"
Axle Joint: Spicer 260X
Knuckle: Closed
Brakes: Drum 10" 11"
Weakness: Weak axle for upgrades, low spline count, weak carrier
Width: 51" (CJ and Jeepster), 57.5" (Wagoneer)
Wheel Bolt: 5x5.5"
Max Recommended Tire Size: 31"
D30 Front Axle:
Full/Semi Floating
Vehicles: From ’72 CJ-5, CJ-6, CJ-7, CJ-8, YJ, TJ, XJ, ZJ, C104, WJ
Ring Gear: 7.125”, 7.33” (TJ/WJ Only)
Stock Gearing: 3.07, 3.54 (3.55), 3.73, 4.10 (4.11)
Axleshaft Spline: 27
Axleshaft Diameter: 1.16”, 1.193” (TJ/WJ Only)
Axle Joint: Spicer 260X (pre ’95.5), Spicer 297/760X (post ’95.5), CV & 760 U-Joint (TJ/WJ)
Knuckle: Open
Brakes: Drum 11” (pre ’76), Disc (post ’76)
Weakness: 260X U-joint; YJ Vacuum motor fails; standard CV problems
Width: 51” (’72-’75 CJ, C-104), 53” (’76-’81 CJ), 56” (’82-’86 CJ), 60.5” (TJ, YJ, XJ, WJ)
Wheel Bolt: 5x5.5” (CJ/C-104), 5x4.5” (others)
Max Recommended Tire Size: 35”
AAM 790 Front Axle
Semi Floating
Vehicles: '05 and later WK
Ring Gear: 7.87"
Stock Gearing:
Axleshaft Spline:
Axleshaft Diameter:
Axleshaft Joint: CV
Knuckle: Open
Brakes: Disc
Weakness: Limited modification ability, small ring gear
Width:
Wheel Bolt:
Max Recommended Tire Size: 32"
D44 Front Axle:
Full/Semi Floating
Vehicles: ’57-’65 FC-170; ’63-’70 Gladiator; '67-'79 1/2 & 3/4 Ton Ford Pickups; ’71-’87 J-Series; ’71-’91 Wagoneer; '72-'93 1/2 & 3/4 Ton Dodge Pickups; '73-'79 1/2 & 3/4 Ton Chevy Pickups; ’74-’83 Cherokee; ’03-’06 Rubicon
Ring Gear: 8.5”
Stock Gearing: Many
Axleshaft Spline: 19 (pre ’71), 30 (post ’71)
Axleshaft Diameter: 1.25” (19 spline), 1.31” (30 spline)
Axle Joint: Spicer 206X (pre ’73), Spicer 297/760C (post ’73)
Knuckle: Closed (pre ’73), Open (post ’73)
Brakes: Drum 11” (pre ’73), Disc (post ’73)
Weakness: 260X and 19 spline axleshafts
Width: 63” (FC-170), 57.5” (’71-’73 Wagoneer), 59” (’74 and later Wagoneer), 65.5” (J-Series), 60.5” (Rubicon), Full Width (Ford, Dodge, Chevy)
Wheel Bolt: (Varies)
Max Recommended Tire Size: 37”
D60 Front Axle:
Full Floating
Vehicles: ‘67-’69 Kaiser M-715; ‘72-‘93 3/4 & 1 Ton Dodge Pickups; ‘74-‘77 3/4 Ton Ford Pickups; ‘77-‘87 3/4 & 1 Ton Chevy Pickups; ‘78-‘79 1 Ton Ford Pickups
Ring Gear: 9.75”
Stock Gearing: 4.10, 4.56
Axleshaft Spline: 30
Axleshaft Diameter: 1.31”
Axle Joint: Unknown Spicer
Knuckle: Closed
Brakes: Drum 13”
Weakness: Metallurgically axleshafts inferior to modern metals
Width: 72.5” (M-715), Full Width (Ford, Dodge and Chevy)
Wheel Bolt: 6x8.25”
Max Recommended Tire Size: 42”
REAR AXLES
D35 Rear Axle:
Semi-floating (’85-’89), C-clip (’90 and later)
Vehicles: Most XJ; YJ; TJ (except Rubicon); ZJ; some WJ
Ring Gear: 7.562”
Axleshaft Diameter: 1.13”
Brakes: Drum 11”; Disc (later ZJ/WJ)
Weakness: Weak carrier & axleshafts
Width: 60.5”
Wheel Bolt: 5x4.5”
Max Recommended Tire Size: 33”
D44 Rear Axle:
Semi Floating
Vehicles (here we go…*long breath*): ’49-’65 6cyl Willy Wagons; ’49.5-’53 CJ-3A; ’53-’68 CJ-3B; ’50-’52 M-38; ’52-’57 M-38A1; ’53-’57 M-170; ’55-’75 CJ-5 & CJ-6; ’85.5-’86 CJ-7; ’58-’65 FC-150; ’57-’65 FC-170; ’63-’70 Wagoneer & Gladiator Pickup; ’67-’71 C-101 Jeepster; ’72-’73 C-104; ’71-’75 Wagoneer & ½-ton J-Series; ’74-’83 Cherokee; ’87-’91 Grand Wagoneer; Some ’86-’92 XJ and MJ; Some ’97-’06 TJ; ’99-’04 WJ; ’96-’98 ZJ
Ring Gear: 8.5”, 8.9” (WJ only )
Stock Gearing: Many, including 3.55, 3.73, 4.11
Axleshaft Spline: 10 (’49-’55), 19 (’56-’70.5), 30 (’70.5 and later)
Axleshaft Diameter: 1.193” (WJ/ZJ) 1.25” (10 and 19 Spline), 1.31 (30 Spline)
Brakes: Drum 9”, 10”, 11”; Disc (Rubicon, ZJ, WJ)
Weakness: 10 & 19 Spline, Some aluminum housings.
Width: 50.5” (up to ’75 CJ, FC, C-101, C-104), 54.5” (’85-’86 CJ), 57.5” (’63-’73 Wagoneer), 60.5” (XJ, MJ, TJ, ZJ, WJ), 65.5” (FSJ Cherokee, J-Series)
Wheel Bolt: Varies
D53 Rear Axle:
Semi Floating
Vehicles: '55-'65 Willys pickup; '63-'69 Gladiator; '57-'65 FC-170
Ring Gear: 9.25"
Stock Gearing:
Axleshaft Spline: 20
Axleshaft Diameter: 1.31"
Brakes: Drum 11"
Weakness: Hard to find parts, low spline
Width: 65.5" (Gladitaor), 63" (Others)
Wheel Bolt: 5x5.5"
Max Recommended Tire Size: 35"
D60 Rear Axle:
Semi/Full Floating
Vehicles: ‘67-‘69 1/2 & 3/4 Ton Ford Pickups; ’69-’87 J-2000/J-20; ‘72-‘93 3/4 Ton Dodge Pickups
Ring Gear: 9.75”
Stock Gearing 4.10, 4.56
Brakes: Drum 12”
Weakness:
Width: 65.5” (J-2000/J-20), Full Width (Ford, Dodge & Chevy)
Wheel Bolt: 8x6.5”
D70 Rear Axle:
Full Floating
Vehicles:’58-’68 FC-170 w/dual rear wheels; ’63-’68 J-3000 w/dual rear wheels; ’67-’69 M-715; CJ-10; '72-‘93 3/4 & 1 Ton Dodge Pickups; ‘76-‘77 3/4 Ton Ford Pickups; ‘77-‘87 1 Ton Chevrolet Pickups; ‘78-‘79 1 Ton Ford Pickups
Ring Gear: 10.5”
Axleshaft Spline: 23, 35
Axleshaft Diameter: 1.5”
Brakes: Drum 13”
Weakness: Poor parts availability
Width: 59” (FC & Pickup), 72” (M-715), Full Width (Ford, Dodge and Chevy)
Wheel Bolt: 6x7.25” (M-715), 8x6.5” (others)
Max Recommended Tire Size: 44”
AMC20 Rear Axle:
Semi Floating
Vehicles: ’76-’86 CJ; ’76-’91 Wagoneer and J-10
Ring Gear: 8.875”
Stock Gearing: 2.76, 3.07
Brakes: Drum 11”
Weakness: 2 piece axleshafts (CJ only), tubes spin, 20 spline
Width: 50.5” (’76-’81 CJ), 54.5” (’82-’86 CJ), 59” (Wagoneer), 65.5” (J-Series)
Wheel Bolt: 5x5.5” (CJ), 6x5.5” (Wagoneer and J-Series)
Max Recommended Tire Size: 33”-35”
Chrysler 8.25 Rear Axle:
C-clip
Vehicles: '91-'01 XJ
Ring Gear: 8.25”
Stock Gearing: 3.55, 3.73, 4.10
Axleshaft Spline: 27 ('91-'96), 29 ('96-'01)
Axleshaft Diameter: 1.17” (27 spline), 1.21 (29 spline)
Brakes: Drum 11”
Weakness: 27 spline, c-clip
Width: 60.5”
Wheel Bolt: 5x4.5”
Ford 8.8 Rear Axle
C-clip
Vehicles: Ford Explorer (Prefered Swap, information reflects Explorer only), Ford F-Series , Ford Ranger
Ring Gear: 8.8"
Stock Gearing: 3.08, 3.27, 3.55, 3.73, 4.10
Axleshaft Spline: 28, 31
Axleshaft Diameter: 1.320"
Brakes: Drum ('91-'94), Disc ('95-'01)
Weakness: C-clip, weak carrier
Width: 59.625" to 65.6"
Wheel Bolt: Most 5x4.5"
Max Recommended Tire Size: 40"
¿... y cual es más fuerte que cual? Esta es una lista del torque contínuo y máximo que soportan algunos:
AXLE STRENGHTS:
COT - Continuous Output Torque
MOT - Maximum Output Torque
Dana 35 ........................ COT: 870 MOT: 3480
Dana 44 ........................ COT: 1100 MOT: 4460
Ford 8.8 28 spline ........... COT: 1250 MOT: 4600
Ford 8.8 31 spline ........... COT: 1360 MOT: 5100
Dana 60 semifloat ........... COT: 1500 MOT: 5500
Rockwell 2.5 Ton ............ Industructable
XJ 97 2.5 TD +4.5" 32x11.5
WJ 01 4.7 V8
